XS650 H/C piston
You guys should know were I can find a piston 11:1 approx, with 20mm wrist pin.
ray.
most retailers have higher than std compression ratio but you have to check with each to find out what that is. MikesXS, 650central, Sheldon Thuet, Megacycle, (Wiesco I believe is less that 11-1) just off the top. Paul.
