Let’s say a guy wanted to get into the chair thing and had a motor. What’s a “good” starter chassis go for?
Paul
Paul
It depends on a lot of things.
Paul Whittaker can hook you up with plans for about $100 or a rolling chassis for around $3500 if I remember right.
Used rigs and chassis vary just like the used bike market. Look closely and you decide.
Running rigs purchased used with a proven history and spares can go for $4500 or less.
Keep your ear to the ground and inquire anytime you here a peep concerning rigs, they are out there somewhere.
Building a main frame and forks, to suit your motor with disc front and possibly drum rear. with hand holds, kneeler trays, fender and nose pan is about 3500. the variables are in the alloy rims v Harley rims, can you make your own exhaust system, do you want the platform covered etc; the finishing bits, wiring, cables, battery box, belly pan, etc take as much time as building the frame and forks. I recommend made to order shocks; NJB from Walridge but you can find used or low end shocks as an example. So to put a firm price on a roller is a rough guess until the lines are drawn. if interested call me after supper is the best time. 613-474-2941 It would be nice if some one else considered building these, I will have to quit some time. Paul.
