Summer Classic Results and Season Standings
The results and standings are (almost) ready to post, with the exception for the finals of Modern Lightweight/Middleweight Invitational, Sidecar Final B and the final for Vintage Open Junior which were pushed to Mosport and/or Shannonville.
I’m having a problem with Modern Lightweight/Middleweight Invitational though. I believe this was a restart for the Finals, but MyLaps only displays the original race and the only timing information in there is the initial transponder pings when the riders crossed the timing loop at the start of the race: 4-10 seconds after the start.
When I try to load that in the database it throws an exception as there is a constraint that checks for that - You basically have to do more than 1 lap + finish the race to score. I’ve reached out to Timothy so if it looks like it may take a couple of days to resolve I’ll remove the constraint and load all the other data tomorrow.
Sorry about this. It took a while to figure out what was going on. I thought I was going crazy.
Thank you Brian.
No Problem Steve
We went ahead and posted everything.
As always, if you see something thats not right let me know. There was a fair bit of manual tweaking this time because of the restarts
