Hello Guys,
I am trying to piece together a Daytona for Mosport, if anybody has some bits laying around, ie. brake parts ,rearsets, tires, crank, please let me know, I will post some progress pics soon. Look forward to going back to my roots on this one (am400 prod. 1977). Cheers, Col
Not exactly factory stuff, but I threw together a reaset… More parts coming next week, Cylinders & Crank look good. Cheers
Do I need a belly pan for mosport? I am hearing not… Wanna be sure.
No, 2012 TT = Yes
If you get stuck finding a part let me know…
Neal
Hmmm still something missing, all because of a crank seal issue…
I had quite a problem getting the rear brake to release properly, found that except for the longest wheelbase setting that the shock was interfering with the caliper and stopping it floating . Anybody see any issues with turing the shock around (resovoir at front). i do not think it will affect the shock action but would like a second opoinion. Cheers Col
I don’t see why you could not mount them upside down? then you have plenty of room for the caliper to work.
Regards Paul
Can you straighten a rod without disassmbling crank? It needs to move approx. .030 thou…
Thanks Scott, That motor was excellent (apart from stuck rings). Iwill post a pick soon… I tried the fairing on the daytona. IT WILL LOOK GREAT. Thanks again and if you need any bits let me know. I may be of help, but it is tough as your standards are high. Cheers, Col
Phase 2 at Quebec, It’s coming (Thanks Mr. Matin)
