Oil & Gas
Guys,
My old F2 used to have baffles in the oil sump … do any of you guys have these ?
Or do you overfill to compensate for oil swish ?
Also what Viscosity of oil do you recommend ?
How do these old engines handle unleaded gas … is this an issue - do they need some kind of additive ?
Sorry for all of the newbie questions.
Mick
I figured the XS sump filter acted as a bit of a baffle, never saw a need to overfill. It’s also a roller bearing bottom end so it can tolerate some oil pressure drop. Been using quality 20/50 dino oil, with some ZDDP added. Unless your going to have more than 11-1 compression Shell 91 works fine.
