Kawasaki 750 H2
Anybody make a New Years Resolution to race in P2H and/or P3H this year?
Looking for a bike that is Ready to Race?
Or, Maybe your looking to come to the dark side and smoke your competition?
This may be the bike for you!
This is a first year (1972) Kawasaki 750 H2, the fastest year for the model.
Weight has been reduced to 365 lbs (without fuel) from a stock weight of 425 lbs
Chambers are rare Bassani chambers with fresh repack on baffles
Transmission has undercut gears (2nd and 3rd) and 3 dog on 1st to 4th
New VM-34 carbs with K&N (cleaned and oiled) filters and cable choke conversion
Clip on Bars, Rearsets and New H2R Solo Seat
New Overlength VSS rear shocks,
Forks rebuilt with new tubes, caps, seals, RaceTech springs, Taper Steering Head Bearing Kit plus a KZ1000 Fork Brace
Wheels have Excel Aluminum 18" Rims, Buchannan spoke kits with Avon AM22/AM23 Tires
Ft brakes feature dual rotors mounted on an S2A hub, SS brake lines, Brembo 2 piston calipers and Master Cylinder
Ignition is stock H2 CDI which does not require a battery to run
Scitsu internal battery powered Tach (verified as working)
Comes with Rear Race Stand, Bin of Spares/parts/manuals plus Information Flash Drive
Price: $6500
Hey Dave,Haven’t seen you in a while I guess you are not racing any more.
I would be interested in the H2 at $3500. If you have an ownership. I don’t mean to insult you but I would not be racing it I would put it back to original and would take a lot of work.
Send me an email
Brad Broomer
autofobe@hotmail.com
Hello Brad,
Well i guess you will have no surprise that i am a hard no on your offer. I have seen broken (blown piston) H2 engine (by itself) go for that $ offer, this H2 has a very healthy running H2 engine and passes compression tests on all 3 cyls. I know what the values are for H2 parts and what they are hammering parts bike special H2’s for on Mercum as of late (saw one go for $32K USD couple of weeks ago).
Dave.
Sold.
Went for a couple of hundred below my asking price.
However, its now headed out west so will not race with VRRA any more.
