FZR600 race bike with spares
Sold sold sold
FZR 600 race bike for sale. Fresh build from ground up with only 2 track days on build. Not been on track since 2021.
Freshly set up and serviced suspension front and back. GSXR750 front end and brakes with aftermarket cartridges. Fresh fox rear shock.
Both ends done by Accelerated Technologies.
Braided steel brake lines.
Engine is 1mm overbore.
Stock cams/cam timing
Head fully refreshed by Scott Miller - recut valve seats and mild porting.
Bike has been jetted and tuned on dyno and makes 90+hp at the rear wheel.
Stock airbox with K&N filter.
Body work freshly painted.
Frame and swingarm powder coated satin black
New windscreen.
Custom race harness. Upgraded new voltage regulator.
Full charging system and electric start (who wants to push start? Not me!)
Spare set of wheels with rotors.
Scrub slicks and rains already mounted.
Front and rear stands included.
New chain and sprockets when built.
Custom upper triple clamp to allow slightly higher mounting for the clip ons.
Rearset footpegs mounts
The tall windscreen offers an excellent tuck in spot for the long straight at Mosport.
Spare GSXR upper triple clamp and clip ons.
3 spare front master cylinders
Spare clutch lever
Spare throttle cables
spare tail section and seat - subframe would need modification to mount.
Spare engine cases, crankshaft with rods. And come valve train parts- cams/buckets
Spare fox shock - freshly serviced - never mounted.
Spare larger radiator. Would need to fabricate mounts and reroute cooling to use.
Two spare exhaust cans.
Some new o rings for water pump/cooling system and oil filter housing.
4 sets of brand new oem stock bore rings.
Some new knee sliders you will need when you are out there setting lap records…….!
$7750 for everything - negotiable dependent on spares included.
This bike is a podium machine and compares very well to my own championship winning FZR.
Can assist with transport/delivery.
Bike is available for viewing by appointment in Norwood Ontario
Photo link here:
photos.app.goo.gl/pWCPeqK5gEsfyhEk7
Come on folks! Race season is coming faster than you think!
It’s sold, isn’t it? :wink:
It is!
Staying in the club too!
