We have all the data from this past weeekend, but there may be a slight delay in getting it onto the website as we need to move some bits and preces out of Rogers/Comcast. Should be up by the end of the week.
It may take a little longer to get this up.
There seems to be lots of anomolies in the data and it looks like its currently just the raw transponder data in MyLaps at the moment.The diffrences are huge. Timothy is going to look into it with Race Control.
This happened with Series Tracker and when they shut it down we lost years of results as we never updated MyLaps with the correct results. I don’t want to get into the same situition again.
I’ve removed the pages from the web site until this is done as they were automatically populated, but if its wrong its not worth being there… sigh!!!
Timothy and JAcqui are still looking at some scoring issues, but I’ll go ahead and post the ones that didnt raise a flag when we imported them
I went ahead and posted the Shannonville results for Motorcycles. You can find them here - vrra.ca/sprint-results-2025/ or under Main Menu->Results->2025 Sprint Results.
There were some issues and some numbers had the wrong rider associated with them, for example 35 and 147 had the riders swapped, so I’ve tried my best to fix them up manually and hopefully I caught them all but if you see any others let me know.
SideCars are not there, there is just a placeholder. There are some scoring issues and its a little above my pay grade to change the finishing order so just waiting on Timothy to confirm and then I’ll upload them. People were asking about their points so I didn’t want to wait any longer
The table format is a little diffrent. I broke it down by period so you just have to go to Finals->Period 3 to see the results for the P3 finals, or Heats->Period 5 to see the heat results for P5. It should be easy to navigate the page.
There were no lap records broken, I think the weather played a large part in that, but if you think you did set a lap record I can investigate.
Season totals will be in a new page but I need the sidecar results to publish it as its automatically generated so it throws an exception as the sidecar results are missing. If its going to be a while I’ll remove the sidecars from the algrothim so the standings for motorcycles will be available
So I went ahead and just posted season standings for Motorcycles. Sidecars is still just a place holder.
It can be found here - vrra.ca/season-standings-2025/ of from MainMenu->Results->2025 Season Standings
We had to rewrite all the import stuff this year as MyLaps moved to Google Tag Manager and I had to manually correct some stuff so let me know if you see an error.
