Peter,
I SURE HOPE it wasn’t mounted on his helmet!!! Notice how, in the video, you can see the rider lying on the track about 50’ away from the camera!!!
Brian D. #43
Peter,
Brian D. #43
Good point there Brian
! I need another coffee…I guess if it was on his helmet he would need head re-attachement surgery which I don’t think is perfected yet
. Apparently, Nortons don’t vibrate like BSA singles!
Peter
My Norton vibrates like an industrial paint shaker while idling and then smooths out fairly nicely when the revs go up. In the Roebling video ( youtube.com/watch?v=EuYrHKk9STA ), while on the grid the camera seems to compensate for this vibration by turning the shakes into a sort of ‘heat wave’ look. I was surprised how well this looked, I assumed the camera footage while idling would be unwatchable. I mounted the camera in front of my tach on the flat part of my fairing.
I mounted my camera in the same location you did Doug but my videos so far have been pretty well unwatchable: http://www.youtube.com/watch?v=p7lsgcVZagU
It may be how that section of my faring is mounted, I may have to secure it a little better. Your videos have the same shake at idle but look great once you get going. Something else to play with! ![]()
Peter
I think a more sturdy fairing mounting might cure it… Things are certainly moving around too much.
Peter, I told you before, the B50 will shake all your fillings out of your teeth so the poor camera has got no chance.
Ray. ![]()
You’re 100% correct Ray, but luckily all fillings are accounted for so far
! Maybe my top secret winter upgrades will help with keeping all fillings in place…time will tell.
Peter
Not to pirate your thread here, but since we’re on the subject of Go Pro Wide Feedback/Sound Quality Issues, I’ve tried to get better engine sound without the noise on my Go Pro Wide, even with the door seal removed, and a piece of tissue taped over the microphone holes, but it still gives off static feedback. Forget recording on HI. Here’s the latest of the camera mounted on a friend’s SV650, no tissue over mic holes, but door seal removed, recording on LO.
youtube.com/watch?v=Nnakjs4JPVA
Hey Doug, I was at Herbs last night dropping off some stuff I need done and I saw your bike. Actually, the damage to the chassis is minimal, the engine casings are a bit messed up though. Amazing what one little stud will do to an engine at high rpms. Looks like she will be up and running in no time, tough bikes those Nortons!
Peter
That’s what I was thinking too the last time I over reved and blew up a motor…
mike
