KAWASAKI F6 125
Complete bike. We got it a couple of years ago because the trans had locked up. We fixed the trans and put new crank bearings and seals in it. It’s still a dirtbike, but if you’re determined it would be a good base for a P1 200 bike.
The frame and bottom end are the same as the F7, and I believe the top end from the F7 may fit it.
It’s been in dry storage since fixed.
$500.00
How does it run rick
Runs OK. Needs a Kill switch…
