1982 KZ 550 1983 GPZ 750
750, good strong motor ( stock ), steel braided brake lines with progressive springs. Front end reworked to remove internal play and eliminate the anti dive. Bike has been raced so its all drilled for lockwire. Full chargig system and starter intact. Comes with belly pan. $2200
550, started off as a KZ and now its more GPZ, gpz 82 motor,ported head,84 cams and carbs.83 GPZ 305 drum rear wheel. Comes with belly pan. KZ 750 36mm front end with progressive springs and steel braided brake lines, super trapp pipe, 83 kz 550 bodywork,original paint. $2500
www.teamkz.ca for pictures
